Wishbone differences.
Wasn't this just the 172 cup? The 182 'extreme pack' wishbones are just the same as non 'extreme pack' wishbones aren't they?
Thanks for the answers peeps :)
Just checking as I sent a message to Renparts asking for cup wishbones and they said they had none
Now at least I know I can buy non cups & they will fit :)
Thanks again! Jon
Excuse me if this is a stupid question, what would happen if you put 172 cup arms on a 182 cup packed?
No such thing as a daft question imo. You get slightly more caster.
Why do you want to change out of interest?
these are the part numbers i got quoted for my 172cup
OS - 8200257957
NS - 8200257956
anyone know what they are for a regular 172/182?
OS - 8200257957
NS - 8200257956
I have a quote from my local Renault dealer for wishbones for my 182, I gave them the reg no. & they gave me the same part no. as for your 172 cup.
I'm a little confused as to which part no. are correct now.
Are wishbones easy to change?
Yes.
Remove the road wheel
Undo the two balljoint bolts (vertically through the wishbone on outside)
Undo the ARB clamps (13mm bolt each side) and rotate the ARB down out the way
Undo the inner bolts (2 large ones running front to back)
Then remove them.
Refit is just the same in reverse
Literally all you need is a few spanners and a jack
