wont turn over
  ph2 172,2010 transit
had my car running earlier in my garage. then the engine stalled itself and now wont start or turn over at all. i turned it over by hand and seemed ok. the throttle body is buzzing when i turn the key.i took the plug off the throttle body and the buzzing stopped but still not starting !!! all help and ideas apperciated.
its a clio 172 ph2
Ill assume its turning over,immobiliser issue? is it getting spark? might not be getting fuel due to tdc sensor....cleaned it?, unlikely as it was running.....
Buzzling is normal from throttle body.
no not turning over at all. the dash lights are on then turn the key to crank and it does nothng just buzzes ! the battery is fine checked it with volt meter and its just over 12.33 volts.
earthed the engine out today and it started first time, happy days although its running really lumpy. so need further investigation needed
