mk 2 172
wot exactly is raw, and wots the benifits over the normal 'fine' qualitly. ive havnt realy used raw because i cant open it in photoshop.
can't stand the sarcy "let me google that for you" replies
RAW files contain raw image data i.e. not compressed/processed. They are therefore more adjustable if you want to fiddle around with white balance and so on afterwards. If you have the camera set to save at jpg fine quality then the camera will process the RAW data and compress it down to a jpg.
nor me mate
thanks gary,so raw isnt nessisaraly 'better' picture quality. just makes editing easyier.
what software can edit raw files?
Usually just people trying to be clever TBH. It is slightly amusing but pretty dull mostly. the people that thought up the idea and wrote the code should take credit, but the people who love to use it in threads they have no interest in should go do something less boring instead![]()
Theres a very simple way to avoid it. You use your own brain which I know is a struggle for a lot of people on here, but its the easiest way.
Ive never bothered with RAW, just use JPEG. Might give it a try as I presume CS2 can open it..
So can CS3 edit RAW files?
i'm having no luck!!
