would wheels fit...?
  MK2 PH2 & E46 330
seen a set of wheels on ebay that fitted a polo.
195-50-R15
rim width - 7J.
would they fit a mk1 clio basically?
(its a set identical to the ones i have, thinking i could replace my kerbed ones)
  Breaking A 172 Replica
The offset is fine, the PCD is fine, the tyres are fine and the width and size of the rim is fine BUT....
The centre bore needs to be 60.1 for your clio but it is only 57.1 if they are actually polo ones. But if they are aftermarket ones they will certainly fit, you just need to buy some Spigot rings.
Sam
  320d
They're defo aftermarket Halfords wheels
Doesn't say what the offset is but i imagine it'll be in the 30's which will be ok for your car
As said above you may need spigot rings
  172
you would have to order the whole fitting kit,they cant just order the spigot rings,full kit including wheel bolts 19.99 iirc
