Xbox flashed up with red ring.
Car  Fiat Panda 100hp
Xbox has been on for a few hours but not being used and not hot. Just looked up at it and it was flashing with a red ring of death, turned off at the mains back on again and it 'seems' to be okay. Do I need to worry?
Bearing in mind i hardly use it maybe and hour or two a week, It was about a month ago, It occasionally freezes frames while playing but thats it, seems fine now
Mine did this like two or three times, then one day it just went straight to the 'Red ring of death' when i turned it on.
The secondary error codes part is more important in this....
E01: possibly a power supply problem
E02: possibly a Network Interface problem (might be fixed by loosening the x-clamps)
E03: possibly Power problem could be the PSU could be the GPU/CPU, somehow the console isn't getting clean power from the power supply.
E04: Unconfirmed: There is a problem with the Southbridge Chip usually dealing with how it connects to the mainboard (cold solder joint/bridged solder joints)
E05: CPU over heating - If you are receiving this error after disassembling your console make sure to all 8 of the heatsinc screws are tightened securely to the board/heatsink holes.
E06: GPU over heating -ensure your x-clamps are installed properly.
E07: RAM over heating
E08: Unconfirmed: GPU Malfunction, similar to error E18
E09: Unconfirmed: This can be caused by two completely different things either:
A. DVD Drive Time out - Can be caused by problems with a firmware flash. This is also speculated to sometime be caused by a problem with the southbridge chipset on the motherboard based on how it connects to the DVD drive.
B. GPU error, generally caused by a poor connection to the mainboard (cold solder joints/bridged solder joints) See error E18 for more information
E10: Unconfirmed: CPU error, generally caused by a poor connection to the mainboard (cold solder joints/bridged solder joints). This can also be triggered by an error with the TSOP.
E11: (not yet known)
E12: Possibly a problem with temperature control
E13: Unknown: could be caused by a short between the heatsink and surrounding capacitors
E14: (not yet known)
E15: (not yet known)
E16: Unknown: Likely a cold solder join in GPU or Ram chips (see error E18)
E17: (not yet known)
E18: Error in the "Digital Backbone" (CPU/GPU/RAM), this is usually caused by a cold solder joint between the GPU and the mainboard.
There are two theories to fixing this one deals with the "X" clamps that hold down the chips. The other involves re-Heating the chips. DO NOT attempt either of these if your console is still under warranty. If your console is still under warranty return it to the store where it was purchased or call MS to have it replaced.
E19: Unknown: GPU Error this is usually caused by bridged solder points where the GPU connects to the mainboard. see error E18 for more detailed information
E20: likely a Ram error, this can be caused by a cold or bridged solder joint on one of the Ram chips.
E32: (not yet known)
E33: (not yet known)
E34: (not yet known)
E35: over heating GPU possibly due to lack of thermal compound.
E45: Unknown (possibly dashboard update related)
E64: DVD Drive Error - Dvd drive timed out during reset :Wrong firmware, dvd is without f/w chip, etc. This can also be caused by the tray not being fully closed on boot. also it could mean that the Kernel can't be launched/signature in NAND Flash chip is broken It could be possible after bad update. http://forums.xbox-scene.com/index.php?sho...p;#entry4156375 This might also be caused by a bad SATA cable.
E65: DVD Drive Error - Dvd drive is not DMA configured :Wrong firmware, dvd is without f/w chip, etc. This can also be caused by the tray not being fully closed on boot.
E66: DVD Drive Error - Dvd drive pairing failure: DVD model, or version does not match that of the version expected by the dashboard. OR the firmware version on the drive is older then the firmware version expected by the dashboard. Make sure the DVD drive is of the same version originally included with the console and that it is using either the original firmware included with the console or newer. if drive can eject, read, and write under windows but errors on console, replacing original firmware should fix issue.
E67: Hard Drive Error - Hard drive timed out during reset: It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it.
E68: Hard Drive Error - Hard drive not DMA configured: It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it. Also this can be caused by a problem with the fans that make them draw too much power, it can also be caused if you have unnecessary accessories attached to the console like an external fan unit. Attempt to remove unnecessary accessories first, and then necessary components such as the hard drive and USB devices. If you have any case mods you may want to investigate those as well.
E69: Hard Drive Error - Reading the HD Security sector failed: It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
E70: Hard Drive Error - Hard drive not found
E71: Dashboard Error - Error within Xam.xex: possibly a dashboard update error, Check below in the "Console Reset Codes" for instructions. If that does not work there is no other solution and the console must be sent back to MS for repair.
E72: Dashboard Error - Error within Xam.xex: Like a problem with the NAND flash
E73: I/O Hardware Error - Couldn't calibrate HSIO Bus from edram: this error is likely caused by a problem with the Ethernet port or supporting control devices
E74: I/O Hardware Error - HSIO related, could be crc error, or many things: There is high chance it's a scaler chip problem (the "ANA" or "HANA" chip near the AV cable connection) it can also be caused by a faulty AV cable so check that first. Microsoft covers this error under their 3-year warranty, this is availble to anyone who hasn't modified their console. contact MS to get a free replacement console before attempting to fix this yourself. Failing that this error In some cases it is a problem with the GPU and may be repairable by doing the x-clamp replacement (see error 0102)
E75: Ethernet Error - Couldn't read ethernet phy vendor: Strange but sometimes caused by the DVD drive not being connected properly.
E76: Ethernet Error - Couldn't complete ethernet reset: This error is usually cased by the Ethernet port's controller chip, a dead chip may not cause the error but removing the Ethernet controller chip does, it may also be caused by other Ethernet related problems.
E77: Ethernet Error - phy request is already processing/reading reg failed/Failed to write reg: This error is sometimes caused by power problems with the RAM chips. It might be cause by a short between the heat sink and resistors or by more serious problems with the RAM. [more info]
E78: Dashboard Error - AsicId check failed
E79: Dashboard Error - Couldn't start xam.xex: probably a file system corruption, it could also be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it.
E80: Dashboard Error - Wrong LDV version in NAND Flash: This is in new dashboard. You have the update but haven't R3T6 resistor. You can:
-Downgrade to old dashboard, solder back the resistor and then update your xbox
-If you have CPU Key, get current NAND Flash image and fix LDV (just add 1 up to latest kernel). (See error 1100)
--==SECONDARY ERROR CODES==-
The specific type of hardware failure can be determined by a "hidden" error code
* Turn the xbox 360 on, and wait till the 3 red lights are flashing.
* Press and hold the sync up button (the small white one), while holding that button press the eject button.
* The LEDs will now blink the first number in the code (as described below).
* Release the eject button and press it again.
* The LEDs will now blink the second number of the code.
* The LEDs will now blink the third number of the code.
* The LEDs will now blink the forth number of the code.
* The LEDs will go back to the 3 red flashing lights.
You should be able to determine the difference between the 3 flashing lights and the error code lights by the rate in which they flash.
Here is how you interpret the LEDs to get the code number:
* All four lights flashing - 0
* One light flashing - 1
* Two Lights flashing - 2
* Three lights flashing - 3
0001 See Error E01
0002 See Error E02
0003 See Error E03
0010 See Error E04
0011 See Error E05
0012 See Error E06
0013 See Error E07
0020 See Error E08
0021 See Error E09
0022 See Error E10
0023 (not yet known)
0030 See Error E12
0031 See Error E13
0032 (not yet known)
0033 (not yet known)
0100 See Error E16
0101 (not yet known)
0102 See Error E18
0103 See Error E19
0110 See Error E20
0200 (not yet known)
0201 (not yet known)
0202 (not yet known)
0203 See Error E35
1000 See Error E64
1001 See Error E65
1002 See Error E66
1003 See Error E67
1010 See Error E68
1011 See Error E69
1012 See Error E70
1013 See Error E71
1020 See Error E72
1021 See Error E73
1022 See Error E74
1023 See Error E75
1030 See Error E76
1031 See Error E77
1032 See Error E78
1033 See Error E79
1100 See Error E80
1444 and up There is no "4" in the error codes. Four lights is a "0" go back and check your code again.
Mine is chiped though so no warranty. Although I did get it with a phone contract which I have no cancelled due to the T&C thing so not too bad.
Yep its fecked only a matter of time like mine :(
A recent survey of 5000 users revealed a 54% failure rate! Personally I think its way off - far to low lol! When confronted by the statistic MS actually seemed quite relieved and just banged on about their warrenty!
do the clamp repair , works a treat i have fixed at least 15 of these by removing the clamp off the console an replacing with the recommended nuts an washers
