Xenon head light
RB182CUP-FF
Car  2118's RB 182 CUP
just been out in th RB and noticed the head light on driver side isnt working, any one recommend where I start to check for the problem in the morning??
cheers
lee
Right I'v swoped both the ballasts over and they both stoped working. So I am guessing that the ballast and the bulb must be f**ked on my drivers side. unless any 1 else knows of anything I dont??
cheers
Lee
Firstly plug passenger side lamp into driverside - this will indicate if its a fuse or not, if it works then...
Try swapping ignitors n bulbs on the driver/passengerside, if that doesn't work...
Try swapping the balasts...if that doesn't work...
Buy a new headlamp
Mine has randomly started flickering on and off tonight. Bloody annoying!!
If its flickering i'd imagine it could be dampness getting into ballast, unless you have sealed it yourself?
but if its flicking and bulb is getting bluer then its mre likely bulb is gna die imo
Maybe you should buy my xenon headlamp that's for sale?
