xenon light adjustment
Car  clio 172
right guys i have recently bought a clio 172 its a 2003 model has the auto lights and wipers but the dipped beam is to low and i cant see anythin is there a height adjuster switch or anything as i have been unable to find it anywhere
Well the height is auto-adjusting but they can be manually adjusted via a white allen bolt type arrangement on the rear of each headlight. Just make sure you have the engine running when you do this or otherwise they will 'return home' next time you start the car.
ye did that mate but its useless the cars been lowered 40mm n the lights go about 30ft n thats it i have to drive everywhere with full beam on
i brought a 182 about 2 weeks ago an my xenons are exactly the same, crap!!!! i wanted to try adjust mine
Mine is lowered and I just adjusted it manually.
Park up infront of a wall with the engine and lights on and just adjust it.
If it won't go far enough take the adjuster off and reseat it to make sure it's not stuck (do that with engine off)
