E edde May 5, 2007 #2 Depends what the fault code is you need to plug into a computer realy to see the fault. Or else just follow my stupid guidlines and drive it more on the ring and the light goes off again.
G Graham Gooch May 5, 2007 #5 Is it the light on the bottom right of the panel, just under the cruise control/speed limiter light. I should add I have a fault code reader/reset unit.
G Graham Gooch May 7, 2007 #9 Matt Wills said: Yeah that's the one. I'll text you Ralph. Click to expand... You knows I'm good
bearne1 Car Clio 182 Trophy. No. 189 May 21, 2009 #10 Have similar flashing light problem, can these be diagnosed using the RS Tuner kit? Thanks
