From the top.
I bought the car with a dead engine, bought new engine, changed the belts, clutch, water pump ect.
Now when she is cold she has a slightly lumpy idle minor car jolt.
Also runs fine shifts nicely.
When warm say at end of journey it will stall when about to park but select times no every time I dip the clutch.
Unless I'm over 2500 rpm she will hesitate really badly so pulling out of junctions is a pain I have to counter rev to keep them up, even a standing start it won't launch until engine is woken up, then yeah it shifts.
I have changed......
Plugs
Leads
Coil
Map sensor
Throttle body
Pedal
Inlet Gaskets.
Air temperature sensor
Any ideas?
Plugs
Leads
Coil
Map sensor
Throttle body
Pedal
Inlet Gaskets.
Any ideas?
