Zenon auto headlight adjuster
  clio 172
Today was working in my engine bay and iv knocked what i can only think that iv knocked the auto headlight adjuster causing it to break. Now is it a part that can be changed or is there a way to Manually cheers
Did you break the actual adjuster or the headlight balast that holds the adjuster in? if im thinking of the right thing, it just twists in and out, if the bit in the light is broken the bit that holds it in, your screwed i think, you'll need to repair it and get a half decent seal else they will steam up. The adjuster its self is replaceable.....
  clio 172
From what i can tell its the bit that has a quarter turn screw in which has a white bit ,il have another look in the morning , couldn't believe it went crack was so annoyed
  Now Sold :-(
Sounds like the adjuster. It's just a quarter turn in and out. There is a small tab that should resist it twisting out that easily. If it feels loose just push it in and twist a quarter turn clockwise.
Before you twist it back in just give it a quick wiggle back and forward to make sure it's still connected to the reflector. If its popped off you will need to clip it back on first. Obvious once you look at it.
  clio 172
Il have a look in the morning. If the white clip is broken is it a case of getting a new headlight cheer. Is there a way to manually adjust it
