Zero Gauge
Jamie
  Audi B8.5 RS4 & 200
What wod be the best way 2 run my Zero Gauge wiring kit on my 52 172 cup ???
  Polo + Micra
same way every one runs there amp power cables
through the bonnet release cable grommet
  Works...kind of...
Check the passenger side bulkhead for any plastic blanking plates.
If you had a Mk1 I could tell you exactly where to run it. ;)
Jamie
  Audi B8.5 RS4 & 200
its a f**king being a pain in the ass Zero Gauge is thick :mad: :mad:
It will go through, bonnet relese place just up under glove box, mine did. Just get a cerated blade and attack the rubber a bit to cut it away, inorder to open up the hole, pull the bit through from engine bay so hole is clear and big, then feed through somthing thin attach teh oawg to this and then pull through and seal up the gap
Jamie
  Audi B8.5 RS4 & 200
thanks will try that
Ah not close then. Yeah its pretty easy, just a bit dodgey to get to with a knife, should be fairly simple when u look at it where to cut really.
  Polo + Micra
0 gauge is not that big
you get need to take your time and have the skills to do it
  172 CUP
Personally i drilled and gromitted just below bonnet release catch. You can't get it through the normal place!
