zorst lowing from cat and brackets working there way loose
Car  182 with cup packs
ok so my zorst is blowing from the cat and this is the 3rd time its happened and also the brackets keep working them selves loose, what can i do to stop this from happening, has any one else had this problem??
would a blueflame zorst with cat-back pipe resolve my problem or would it also do the same on that???
is it the ball-socket joint your referring to. you could pack the joint with exhaust sealer, and to use some locking bolts on the threads of the exhaust clamp. they have a nylon top to the bolt which is cut in with the thread of the bolt and locks them, making them more secure than conventional?
