Ph1 T
Post the vid up of us Lew![]()
+1 I'm getting pulled more away from cams and itb's reading through this
Making the car lighter.
GRP panels
Polycarb windows
Excess metal removed
Lighter wheels and other aftermarket parts.
If its for track use then absolutely, it will also make it corner better and brake better.
Lightness is the best thing you can add to any car.
If its a daily driver though, I think I'd sooner have boost than a stripped interior.
For me it's ITBs all the way on these cars, but not necessarily for straight line speed. You can't argue if that's what you're looking for, forced induction is the way forward. As above you can take a fairly tatty F4R and run as much as 250BHP 'safely' for a fair amount of time. These engines don't actually like revving all that much anyway, at least not when you look at other tunable NA lumps. So you're almost doing it a favour
Are you able to do basic things like a cambelt change yourself or are you a typical cliosport mong? lol
So what would you say chip for labour looking at about another 1k+ for labour?
Only slight problem with that is you will end up paying to have it mapped twice as the moment you drop the CR to allow more boost, you will invalidate the ignition curve that has been mapped for standard boost.I'd be happy running low boost until the belts were next due like you said.. Tbh this is my first ever project in doing so still learning a lot (only 21)
To me thats the best thing about car forums, they are a great place to learn and to teach.Definately learnt a fair bit of here though
I've got some from our antics in germany, they've got your plate in them. They ok to share?
You can upload to YouTube with invite only I believe so it won't come up in search results?
Then let me proof it
I supercharged mine for £3k and it included standalone and getting cambelt done.
May be a daft question, but if budget wasn't an issue could you do cams, itb's and turbo/sc?!
The ideal cams for a turbo motor are not the same as ideal cams for a N/A motor, so they wouldnt be the same cams that people normally fit with ITBs, but yes of course, and typically you find most turbo motors will run a single throttle body as it keeps the mapping so much simpler.
What I did on one of the engines I built was basically build a touring car spec N/A engine on steel internals and solid lifters etc, and then instead of touring car spec cams, use milder ones, and instead of touring car spec high comp pistons, used forged low comp instead.
Then the ITBs I used as a manifold essentially, with a shared plenum before them and a large single throttle (like on the S2000 cars).
Made for a very efficient turbo engine indeed.
Looked like this on the intake side:
Surely if you factored into the value of your car + £3000 thats one hell of a fast car that can be purchased for say £5000. I'm the same as you Dan I want a faster car but throwing my money at a W plated Clio makes no sense to me. But hey I've a few more years on you and at the end of the day its your money and your car.
just fold the mirrors in
Cheap to maintain too once it's turbo'd if sticking with a standard bottom end.What can you get for £4500 that has 250+ bhp, weighs about a tonne, (ruling out an m3) handles as well as a Clio, (ruling out a vauxhall) is relatively rot free (compared to jap crap) and is as comfy to sit in (Ruling out a caterfield)
Duct tape on the panel gaps.
Type R, Scooby, Westy, Caterham, MKII GTI with any engine you want, 205GTI, tuned MX5, Sunny GTIR the list is massive. The scooby may be over weight but the rest are not that eavy, can produce great bhp and are under £5000 to buy.
In my defence we done a rolling start in both of them races as per Danny's choice, and we were starting about 2.5k rpm, which was guttless in my car, 421's really had no low down power, once i hit 5k you didn't pull as much on me, the off the mark race at Eye airfield was a different story![]()
That was why i wanted a third gear start on the motorway in Belgium, but then we slowed down to 40 ish which wasn't any good for me lol.
I'm not saying my car was more powerful, just wasn't that much in it.
