Colour coded cup splitter, £20ish
Pull airbox top hose/feed out = Free induction noise.
got a pic? and doesn't that add more heat into the engine? not sure where you mean ( suppose i should look but easier with pics!)
iv heard of a few people that have done this (pulled the CAF pipe out) cant comment on that myself as what iv done is drilled and smoothed the standard airbox which gives you better induction noise, add a panel filter too and get slightly more (like me) sounds frickin awesome
ye but not till after the weekend am away from home just now. Its pretty easy anyway if you look in the airbox youl see loads of little fins. They absorb a fair bit of noise and getting rid of them gives a nicer induction sound. And if you want more noise still you can drill a few holes in the bottom half of the box. Just make sure they are all below where the filter sits and somewhere that wont suck in much heat. I put a couple in the very bottom and a few beside the battery. Also prob obvious at just in case - take the box out to drill it. So you dont burst any pipes etcCan you put up a picture of this so we can see?
M3 mirrors & color coded
Hand brake
Sub & amp
Color code engine bay
Goodridge stainless brake hoses
Sun strip
Mud flaps
Wheel spacers
Remove rear seats and recarpet
Fire extig.
First aid kit
Harnesses
Wheels painted
Oil cooler
Roll Cage
Momo wheel
Gear nob
FLOL.the impression i got from that post ive put in bold.
Sand paper on the melted "leather" RS steering wheels, gave mine a blast with some 80 grit the other day to remove all the lumps and its loads better :approve:
A good clean!! Costs sod all, but a clean car makes all the difference! More time than money!
Even if your not into detailing, a nicely polished car looks mint!
In my opinion, if your low on cash, your better with a very clean standard car than some bodged attempt at mods!
New number plates as above, freshen any car up!
where can you get the raised numberplates from?
a good service done by yourself, a damn good clean, hoover inside, full tank of fuel and a good blast knowing that your car is 100% mint!
This is probably a stupid question and answered many times, but are ph2 rear lights literally a straight swap for ph1s? Anything required other than the cluster itself?
remove the spair wheel and jack then chuck in sum tire weld and a bike pump.Saves on wight
buy a cup?
are the rear LED number plate lamps legal? looks great
buy a cup?
Not everyone wants a cup...
