What is this cover used for?
vjs
Car  Clio 172
Any thoughts on where this cover is used for? Can't find a place for it :)
I suppose it's place is somewhere there :) or do I miss some other covers?
You see where there is a trapezium shaped piece that comes down off the chassis leg and the the subframe bolts to it. The cover goes there with the while in the cover lining up with the hole in the chassis leg.
Its held on by just clamping around the edges of the sheet metal.
If that's your car, get some more pics up. Looks immaculate.
I try to get where it should be :) Is it driver side or passenger side?
I can't remember for sure but if you look at the trapezium shape on the cover you can then match it up to the trapezium shape on the chassis leg.
I think its the drivers side though. Give it a try.
Nothing on the drivers side like that. There is sometimes a shitty fabric sort of cover, but they are missing 90% of the time.
