tonyd106 Car 182 Mar 4, 2014 #1 Basically I was giving my mate a hand to change his engine sand came across this connector Can't see a plug anywhere that would go in there :S
Richard102 ClioSport Club Member Car Clio 172 cup Mar 4, 2014 #3 looks like speedo drive? on top the gearbox yeh?
Daniel ClioSport Moderator Car Whichever has fuel Mar 4, 2014 #4 Looks like a ph1/cup box in a ph2 car. Ph2 gearboxes run the speedo off the ABS ring from memory so that would explain why there is nothing plugged into that ph1/cup gearbox hole. Got a bit of an oil leak too! lol. Best off asking Dan@SJM or one of the other geniuses on here.
tonyd106 Car 182 Mar 4, 2014 #5 yea the engine in there is leaking from everywhere possible and is fudged. That makes sense then if it's an earlier box.
tonyd106 Car 182 Mar 4, 2014 #6 Richard102 said: looks like speedo drive? on top the gearbox yeh? Click to expand... Yea it's on the gearbox (that's what it looks like to me anyway). Speedo drive sounds like a good shout to me.
D Dan@SJM Car 07969 124504 Mar 5, 2014 #8 sideways danny1 said: Should be plugged in on anything but a 182 Click to expand... Or later ph2's. IME anything from 52 onwards, although though, you can reconfigure the clocks on the ph1b's to run off the ABS.
tonyd106 Car 182 Mar 5, 2014 #9 Dan@SJM said: Or later ph2's. IME anything from 52 onwards, although though, you can reconfigure the clocks on the ph1b's to run off the ABS. Click to expand... Yea his is a 53 plate so is a later one. He'll be done to see you soon about belts and a few other bits.
