Windscreen Rubber Split - Replaceable?
So the rubber around my windscreen is looking a little tired and there's a noticeable split in the top corner passenger side.
This is probably why I get drips on the passenger floor when it rains.
Anyway, Is this a Renault replacement part? Or will any old body shop have something to suffice?
Wouldn't even attempt to do it myself. Unless someone comes along and tells me it's extremely easy.
So yeah, has anyone done this or does anyone know more about it?
I would suggest that you check first where the drips are coming from. Maybe you need to reseal the windscreen. I dont think that you can get water in the car from these. The corner part is on the vertical so its far easier.
I changed all the 3 bits and although the 2 vertical are easy, the top one was a nightmare.
Plan on giving it a wash at the weekend so going to use a hose to try and work out where the leaks are...
