renault clio 172
Does anyone no if 197 cams fit in a 172 and what is the normal topspeed for stanard 172 thanks
You are probably best of putting this in the Engine, running gear etc section.
I'm not sure personally but that will be where you get the answer
Would not bother with the 197 cams unless you put an rs2 on with a remapDoes anyone no if 197 cams fit in a 172 and what is the normal topspeed for stanard 172 thanks
My ph1 has 197 cams only and they are awesome.. If your having belts done id definitely fit them as a budget option.
You like them too Jacob![]()
Yes and the Ktec jenveys sitting in a box when I can get around to have them fittedIf I remember rightly, you have 438 cams on yours don't you?
