Hunting idle on phase 1
Car  Ph.1 172, FD3S RX-7
Hi guys,
The idle on my 172 occasionally hunts around 1,00-1,500rpm. Seems to be completely random. Google suggests a new air temp sensor, any other suggestions?
Cheers!
Yeah, I did think that as the idle was initially just sitting high until you blip the throttle.
Why would it hunt, ECU trying to adjust it with fuel/ICV?
whoa mate, my issue exactly - replaced the ICV and the TDC - and no good.
did you find a solution? does any one have a sollution?
Hi guys,
Cheers!
Same happened to me, my map sensor was loose and I changed throttle body, all sorted.. I used a throttle bodie from a 99 megane 8v,
Good info, cheers mate. My TPS seems a bit dodgy and has a suspicious cable tie on it so definitely getting it replaced!
