Gears/Gearbox Misbehaving
Car  Renault Clio
Hello guys can anyone maybe diagnose this
My Car has been playing up lately, my gears are really stiff going into 1st & 2nd gear, and it don't slot in the gears properly and make a hideous gears grinding noise :-(
It tends to be worse when I haven't used the car e.g overnight or after work
Any ideas?
Thanks
Luke
Oh I see whoopsies, *embarrassed face*
Just done a check and oil is all good,
Phoned local garage and they said it could be a bearing in the gears worn, does that sound like a possibility?
You've checked the gearbox oil? Not just the engine oil?
Tbh, if i was you i would drain the gearbox oil and replace it with 3.1L of oil.
I replace mine often.
