What is this adapter thing?
Ex-User (72296)
  Clio 172
Hello..
I've seen before people have a device plugged into the wall (ethernet port) to pick up wifi signal, which then distributes it again for you to pick it up again.
The reason I want this is my xbox and wifi printer won't pick up my Uni halls wifi because it isn't a simple password entry, you have to enter student ID, unique pw etc.
What do I search for to be able to find the above?
welshname
There are things called powerline adapters.
They plug into the router via Ethernet, then into a standard wall socket. Then you have the same on the other end but into your device.
Nothing to do with WiFi but I think its what you actually mean.
  BMW M4; S1000 RR
Both of the things mentioned so far exist.
Not sure what the former is called, Wifi extender would be a good guess I'd have thought.
Ex-User (72296)
  Clio 172
This is it!
http://www.argos.co.uk/static/Product/partNumber/1983566.htm?CMPID=GS001&_$ja=cgid:12504951290%7Ctsid:59158%7Ccid:200290250%7Clid:94813109090%7Cnw:g%7Ccrid:42772543250%7Crnd:13186470794695780633%7Cdvc:c%7Cadp:1o2%7Cbku:1
  DCi
This is it!
To make this work you would need to plug one of this in you pad then the other one near wherever the network is coming from
Then whoever is responsible for the network would have to let you patch it in
And you'd have to hope this is the same building or it won't work.
Not sure if you have a PS4 or Xbox but if your uni wifi needs some kind of authentication (ie your info) I know you can connect a PS4 to a BT hot spot, go to the browser and log in to get 'normal' internet... I assume you can do this on your uni wifi
But probably not ideal... Does your Uni room not come with a Ethernet port somewhere?
Ex-User (72296)
  Clio 172
Thanks for the help mate.. but that's not correct.
Ended up speaking to a room mate who has just given me the password who uses the exact one I posted above. He has just plugged it directly into the ethernet port, which then creates its own hotspot.
  BMW M4; S1000 RR
From your OP it sounded like you wanted something that could login to a wifi network and then rebroadcast it.
What you've posted above is just a wireless access point.
