100% on the flat ? Tyres the same size ? Tyre got air in it ?
Shocks standard parts....? They have a tendancy to leak/blow... Does it feel OK to drive ?
Does it corner the same, left and right ? Does it wander or feel skittish at all ?
Stick your head under the car (jack the rear up if necessary (FTLOG don't use the Renault 'widowmaker' jack !!!! ) ) and look at the shocks. If there's any residue on there, they might well be leaking.
Always the classic 'bounce' test where you see what sort of compression etc you get, but if you're that clueless it won't tell you much at the moment![]()
55 profiles ??
WAAAAAY too large.
Should be 195 or 205 wide .. 45 profile 16" rim.
What an amateur....as I was taking pictures to upload I noticed the 3 other tyres are Michelin pilot sport 3 205/55/r16 and the other is not and its 195/55/r16. The tyre wall is about half an inch bigger! Mystery solved haha
Have you just bought it or something? I would be straight back
Over a tyre that is the wrong size and illegal....yes! without a hesitationYeh had it a week and take the car back over a tyre?
