Home brew almost sheep boost bus build ect
I was always going to make steel ones if I ever went forged. The omex ones were the absolute firsts to be made so are almost prototypes!
@marinemackay2003
Hay bud, as discussed....photos...hope these help.
You can see clearly where they have worn away / warped the bolt holes under load. The worst is the very 'thin' bolt hole in photo 2 and 3. Close to snapping when it came off the car. I have new k-tec brackets (didn't buy them) but i'm going to speak to @Dan@SJM about the potential for a repeat performance tomorrow when he is fitting the kit.
yeah i agree Chris, fairly flimsy design, looking at the bolt hole that cracked, there is only 1 mm of aluminium on the outer edge of the hole and only 2.5 - 3 mm in depth from where the have drilled for the bolts
making it out of steel should sort these issues though
wonder how many have had these fitted and have had issues with them breaking @tom172cup
That's another reason I don't go to gaytec anymore. There workmanship is shite. That bracket of mine has done 8k max
I had the first revision of that which had a similar bracket the inlet side too. It cracked but in a non important area.
some recent random updates
got my gearbox back, so gave it a quick clean and decided to paint it in vht black, looks much better
Before
After
also bought some headbolts from Eurocarparts for £28 -Bargain
i was worried about getting a base map, start up calibration for the Omex 600, But after a little search on here, i found out that Omex will make you one for free
Result
So if any one wants a base map for a forged, Supercharged clio on 630cc injectors with a 3 bar map sensor pm me
Currently in Norway for 6 weeks with work, cant wait to get back to start putting it all together
Been slowly buying a few bits whilst in Norway, got back today to get it all
some steering rack bushes, and a 3 bar map sensor from brands hatch performance, seems like they have the best after market copies of the original Weber Marelli sensors,
now to wire it in to an omex
also bought a megane crank pulley but not the bolt ( idiot ) and the head bolts arrived, so now i need my timing tools back @Chi and can make a well well over due start at bolting it toether
Managed to get my steering rack bushes fitted last week - what a s**t job that was
And today I took a trip to TTS to sort out a larger supercharger pulley, I went to a 90mm instead of the standard 85 mm so I should be able to rev to around 7600rpm without over speeding the charger, really nice guys and have a great workshop, changed the pulley over for free for me . Result
Some nice cars there
