So I messed up and I now I have loads of adverts...
  Hondata'd EP3 Type R
Hi, Long story short I tried to install a PS2 Emualator to relive my child hood, and ended up failing miserably. I run Windows 8.1, and Mozilla Firefox.
Every single page now has an immense amount of pop ups and adverts. They come up everywhere, the adverts are in boxes with "powered by" in small letters then it has things like "group coupon" and "deal2deal".
Google isn't the same either. It looks the same, but it has 8 squares underneath the search box with various links. Also when I search for something on google, the top 5 or 6 matches are adverts. Random words on this forum are highlighted and are "links" to shopping pages?
I have no discs etc, I dont care if I lose everything and start again, I just want a functioning web browser again :(
Thanks
ChrisR
Personally I'd want to just wipe and start again, you may never know what nasties have got onto the machine.
But you can try running stuff like Malwarebytes, AV scans etc to see what they pickup.
Here's a good start https://www.malwarebytes.org
CrippsCorner
  208 GTi
I had some something similar recently, Groovorio it was called! Nasty thing. I reinstalled Windows and it was still there! Ultimately had to manually delete from all browsers etc.
  AB182, Audi A5 3.0
you didn't re-install windows correctly then, sounds like you didn't format /fdisk the drive fully first!
at OP, use malwarebytes and if that doesn't work (it probably will, but make sure you run it with windows in safe mode), use a boot time scanner like avast's.
CrippsCorner
  208 GTi
I used the reinstall option Windows 8.1 comes with. I haven't got the means to format c:\ from scratch as I've not got a CD drive or 16Gb USB stick :(
safemode? lol
Is it possible to start again with no discs? I have nothing on this system of any use?
Thanks
