Just fitted catcams 438. Sounds awful, help!
Car  Clio 200 + Clio 182
As title says.
Just finished fitting my new cams, dephaser, belt, ac delete kit etc.
Started it up to be greeted to this:
To me it sounds as if its misfiring. I've got no EML on yet.
Im 99% sure the timing is correct although my first port of call will be rechecking it, surely it doesn't sound this bad just because it hasn't been remapped?
Cheers for any help
That's something else I was thinking, but again I'm sure they are in the correct order.
First thing to check us your ht leads. That was my first thought when it eventually started.
Not that I've ever put them
Back in wrong and had a similar noise....
I tensioned it up with all pulleys loose, tightened, turned it over twice tool slipped in lovely.
Everything was torqued up correctly, this is my 4th belt change on a F4R and neither have sounded like this before :\
Only thing I can think is that when I was taking the dephaser from the inlet camshaft it had been over tightened so much it bent the tool and the camshaft slipped around onto a TDC locked engine.
I had to angle grind the dephaser pulley off in the end and it wasn't even the dephaser bolt it was the oil seal cap!
I'm talking a quarter of a turn, would that be enough to bend a valve? They all seemed fine when I felt through the inlet holes.
The only valves that were slightly unsealed when it was timed up were the inlet valves on the 3rd cylinder (2nd in from belt) and I thought the piston on cylinder 2/3 would be down when locked at TDC?
Engine ran fine before I took it apart - even though it hadn't been timed up properly from a previous belt change.
I can't get back to the car until tomorrow as I'm away at the moment.
Sounds identical when cranking to when i first put the F4R in my MK1 >> http://vid133.photobucket.com/albums/q51/laine_16v/Ressurect PNX/MOV00693.mp4
As determind above one of the cylinders will have 0 compression. I am never sure exactly what caused it but i removed the cam cover compressed all the hydraulic tappets in a vice, put it back together, and it was fine. One or more valves are never being given a chance to seat properly, hence the cylinder never builds any compression.
It wont be any terminal damage imo, id at least start with what i did.
That sounds like it could be possible. Thinking back it didn't feel as their was much compression when I was cranking the engine to check timing....
Thanks for the ideas :)
After squeezing the tappets did you fill them with oil or crank the engine over with the coils disconnected to prime them?
I've had issues on a different engine upon changing the cams and lifters where 2 of the lifters had 'locked out'. I took them all out, drained them all, refitted everything and it was fine then.
Ok, well checked my HT leads and as I suspected they are on the correct way, tried a bit of WD40 still no luck.
Going to have a go at the lifers in the morning as I'm pretty certain I've timed it up correctly.
Tom once you've drained the lifers do you just put them straight back in or do you prime them with oil again?
Y
You need to prime them by submersing in diesel with them sitting vetical. Guess you'll be starting again then if you're checking them.
I put them straight back in, timed it back up and then started it. It was a bit tappy obviously until the lifters filled up.
Went from a dog of an engine running on 3 to purring like a kitten. Until then I didn't know lifters could lock out!
Never owned a car with a Ford CVH in then. They did it just for fun. My friend found the wrong gear in my XR2 and spun it up enough to Jack up the followers and bend 4 exhaust valves. Thankfully followers are more robust these days!
Did a compression test this morning.
0 on cylinder 1
120 on cylinder 2
didn't do 3 or 4 as there was no point.
Stripped it down bled all the tappets put it back together and it still sounds like an absolute dog :/
Not done another comp test yet but when I had the cams out I was turning the engine over without much effort at all and it sounded as if a lot of air was being forced out from a cylinder somewhere.
I guess having no cams it means all valves are closed?
Also it seems to like idling at 2k rpm.
Arggh :/
What tools have you used? I know someone who is a specialist fitted a set of 438's last year and got it very slightly wrong and when the Dephaser engaged it was clipping valves. But also 120psi is crap. I'd want to see 190+!
If you're turning the engine with no cams and it was easy/air escaping (providing plugs were in it) then you've bent valves.
Yeah, I'm sure I've bent a valve on cylinder 1 when the cam slipped round.
When I was taking it apart on the inlet manifold for cylinder 1 there was black liquid stains which I assume were petrol coming out the inlet.
Next step is to take the head off...
Yep. Fortunately my girlfriend has an engine that spun a big end bearing... now to sweet talk her into lending me the head :)
