More brake issues
Hi mate thanks for the reply,
The vacuum line is definatly connected up at both ends
The systems not been bled yet as im waiting for a new caliper as the bleed nipples snaped when trying to do it, should the pedal not go solid when the engine is off?
Scott
Cheers all i will get these sorted at the weekend, got the pressure bleeding kid and 5 litres of brake fluid (Bit of a overkill i know but you can never have too much brake fluid) :)
I'll report back at the weekend
Cheers all
Did you check your calipers pins aren't seized like I suggested in the last thread? I had the same symptoms....
have air in the module of abs , you need to purge with renault clip or blow up the abs to release the air.
I had to do in my car 2 times
Hi All
Managed to sort the issues now :), new caliper on and pressure bled the system. The amount of air that came out was unreal, tbh theres probably a small amount of air in the ABS pump but thats another job for another day and the brakes are 100 times better.
Thanks for all your help
Scott
