fog light on display flickers when brake pressed
Car  clio v6
Hi when i press my brake pedal or turn my indicator arm the rear orange fog light on the display flickers.Now ive read a good few posts about poor earth on the clusters etc and ive checked everything and cleaned everything but it is still doing it .the earth wire is making good contact with bolt as when i rub it on the metal i sparks so its making contact ,ive checked both lights and cleaned all plugs.any help most appreciated on this please.
Its ok ive sorted it lol.bent the contacts a bit further on the plug on drivers side and is ok now.:spanner::up::smile:
The plug that goes onto the bulb holder i closed the pins tighter and all is ok now .so if anyone has this problem it can be either a bad earth contact or the pins in connector not contacting tight enough.but im sure most will know this.
no, this is a very common problem that's hard to fix
got a photo of exact pins, detailed info is very welcome
Yes see the black plug, get a thin screwdriver and close the the prongs tighter together then this should sort it out.
I bit of a bump for this……
I noticed tonight the fog lamp symbol on the dash was flickering under braking. I had a quick search on CS and it seems pretty straightforward what I have to do (my 1982 XR3i had this problem every bleedin’ winter!). I’ll get it done tomorrow.
As it’s a connection issue I’m wondering if the heated rear window connections run through the light cluster. Mine only clears the bottom half of the rear window and I’ve checked all I can on the tailgate and found nothing wrong. Could it be a dodgy connection that runs through a light cluster?
