Valeo Clutch Kits
Nyall
Car  Titanium Ph1 172
My Ph1 172 is going to need a new clutch soon, so looking to replace it with a Valeo kit.
I know there are two Valeo clutch kits available, one for the Ph1 and one for the Ph2, however, I understand that a Ph2 clutch will fit the Ph1?
Here's the two clutch kits on ECP;
http://www.eurocarparts.com/mobile/...d6cf88f44f65dc1fc6f02d72f207dde6c17518&000069
http://www.eurocarparts.com/mobile/...07298c6b7c40f11deb0bdaeadfe6ee1949dcc6&000069
The first kit is for engine codes F4R 730 - I assume this is the Ph1 kit?
The second kit is for F4R 730 and F4R 732 - I assume this will fit Ph1 and Ph2 cars?
I've also read on here that the Ph2 clutch is slightly better than the Ph1?
Anyone have any info on this?
As above.
If you look at the Valeo website they are also listed separately with 2 different part numbers, but they are the same.
When I owned my Fiat Coupe I bought a new LUK clutch from bypartsby.
When it arrived it was a Valeo Stamped clutch in an LUK box and about £70 cheaper than the "Valeo" one.
