Which sealant for doorcards?
Car  Ex 182 owner
Hi Folks,
which type of sealant is best for re doing the doorcards after swapping them out?
Chris
Why use sealant? Just use the furthest screw points at the bottom as guide points and start fixing from the centre outward.
as above, no need to re-seal the door cards.
If you'd taken the plastic off, then that needs some sort of never-setting mastic
That's more what I was getting at.. They have sort sealant/ mastic when they come off.. It's this I want to replace. I just don't know what is best. It will be screwed on as normal.
