Trackslag172
								03 Clio 172
				Hello,
After fitting BC coilovers and poly bushes all round, the caster of the front wheels has increased by a noticeable amount. Normally this would be a good thing, but not in my case. The car is a track car and unless I raise the suspension up much higher then I would like the wheels rub near the front of the arches under heavy cornering. see pic below
I was going to cut out the metal that it was rubbing on (as I have with all the other problem bits of metal) however the arch looked quite important, so I think I will leave it in.
Can anyone recommend a way to reduce the caster again so the wheels sit closer to the center of the arch?
image posting
Cheers,
Tim
image posting
Cheers,
Tim
