Clio Sport 182
				Hi
I've had a look about and cannot seem to find a solution to my problem. 2 weeks ago I had a big problem with my clutch gearbox and that's now sorted. the sub frame was removed to get the gearbox out and while doing this the steering column came off and had to be re set in place. since doing this i now have the ESP ABS and SERV lights on. Here's where it gets confusing, I logged on to OBD2 and it has flagged up both rear ABS sensors at fault. Is this a pure coincidence that both sensors failed as soon as this was replaced or am I missing something and done something wrong. There is no fault on the steering angle sensor and no fault on the brake position sensor. Is there anything I could have knocked or damaged to cause both rear sensors to fail simultaneously as I never had this problem before doing this work.
Someone please help me its never ending!
