Clio sport 182
Jb21, yes if you have a failed sensor it will disable your abs system and light up on the dash. As far as I'm aware if your abs lights stay on when you turn the ignition it's either a sensor fault or a supply fault (like I had). If it comes on after moving the wheel it's usually the steering angle sensor. If it is off when you turn the ignition on and then comes on when moving this is either a abs ring fault (cracked, got grease or a stone in it or a tooth missing) the rings can be replaced and I believe they are about 10 quid a pair online
I have the same problem esp abs light is on from turning the ignition on. Replaced all sensors, disks and pads and abs rings on the front.
When the garage done a dignostics test on it it came up with the fault 5020 does anyone know what this fault is?
I am yet to try testing for power to all sensors tomorrow after reading the hole form.
Just just after a friendly advice before wasting anymore of my time with the car.
It makes it harder that the car has no mot now as they wont pass it with the abs light on
