Should Cobra subframes need drilling?
Don
Car  182 & LY Clio 220 ed
Got a subframe for my Clubman seat to go in the 182. I've tried to line it up and it would appear that only 2 of the holes are in the correct position.
I've marked up where the other 2 holes 'should' be but unsure if I should just go for it.
The subframes were bought with runners direct from Cobra Seats.
Any help/advice greatly appreciated.
I'd just go ahead and drill it. I had OMP frames in my last car and the holes were also out of line slightly also.
  • Like
Reactions: Don
Surely that is upside down or have you intentionally done that just to show in the pic ?
I was trying to show the only way the holes will line up. If I put it the other way around it goes nowhere near fitting.
@JON FOZ
How much for a standard 182 drivers subframe (normal, not x-low) and I would be looking to pick up this weekend if that is good with you.
You sure they haven't sent you the wrong subframe? I ordered a drivers side direct from cobra and had this exact problem, yet it's fitted perfectly on pass side
@JON FOZ
I don't bother with standard height subframes now as the demand is not there since the X-Lows.
You can alter the height on your sidemounts or space an X-Low up if required
I haven't got side mounts.
I've got the runners so I can adjust it back and forwards. Would this cause a problem or do you know where I can get spacers from?
Ps. How much collected?
£70 collected for a single X-Low
