OZ Ultraleggera 16x7 Et30 4x100
Hi
I have many questions if this wheels with this specs will fit well my 172!
Anybody use them? if yes do you have photos?
This will clear the car not touching anywhere? I have a Bilstein Coilovers
Thanks for the help
I have those wheels and they will fit fine, Also have bilsteins. You may get a little scrub on the front but nothing to worry about.
Can you post a photo?
The scrub is just in corners?
And in the rear?
Thanks
My bilstein rears are as low as it will go but does have the adjustable spring holder. The rears dont scrub. The front is sitting pretty low (two finger arch gap) it only ever scrubs rarely when going over dips in the road etc. The place it scrubs is on the little flap of the arch liner that covers the top main bumper bolt. ET30 is nothing to worry about and will be fine. Cant get any pictures at the moment.
I know the ultras in that size and bolt spec is only ET37, never heard of 30.
I have the same wheels, with no spacers and federal rsr tyres. The rear tyres used to rub on the arch (top of it) but had the arch pulled out a bit and it's fine now.
The fronts rub in heavy downhill cornering somewhere on the arch liner area at 10'o clock position as you look from the side of the car. Some people grind the piece of metal and job done :smile:
