172 Cup
Evening! Sorry it's been a while since the last update, as I'll explain it's been a busy couple of weeks.
To cut a long and very frustrating story short, I was let down by the (nameless) people who I'd asked to design & CNC the bellhousing, wasting about a month of collaboration, so had no choice but to take the work on myself. It's not something I've done before and it's a very large and expensive chunk of scrap if it doesn't fit properly, so I took a bit of time to get it right!
Measuring up the engine mating face was a massive pain.. especially without any specialist CMM equipment.
The Formula Renault starter motor was awkwardly mounted up inside the bellhousing and there was no space for it with the new part being so much shorter (as well as the motor itself being obsolete now) so I decided to revert back to Clio parts and future-proof the build. Now it uses a TTV 184mm race flywheel and AP twin plate clutch, as well as a standard Clio starter in the normal position.
Some bellhousing pics:
It's been sent off for CNC now, so time will tell if I got everything right! :fearscream:
The chassis is also coming along well, and the driving position is almost sorted. This has been a very tricky thing to get right and has taken a lot of time, but it's definitely worth the effort.
Seats have 3 options for lateral position as space is tight!
Don't worry, that isn't where the steering wheel will go!
I've also been finishing up the frame.. just a few more bits of tube to go. You can see in these last 2 pics how the drivers seat has been offset towards the centre of the car to try and get enough space - the 205 is a small car!
