Mot emissions
Car  Clio 182
just had my 182 mot'd and the emissions were 7% over.
It's got a cat fitted.
I've no warning lights and the car drives fine but seems to use more fuel than it should.
Recently swapped the map sensor.
Where do I go with it now?
Could be lambda failing, even without a light. You'll need to check the live data if you can however the fact it's using more fuel would suggest a pre-cat lambda issue.
Did they test the car once it was fully warmed up? If the car isn't FULLY up to temperature then that can effect the emissions quite a lot. You could also try some of the treatments available, perhaps someone with more experience of them can advise you.
I'd agree with last post -essential to get the car proper hot before test, I know this is not always practical, but it can make a difference between pass and fail if emissions are slightly out.
Out of interest guys. When you say proper hot, the cars are generally left running when the tester goes about checking the car and it will be up to temp. Is that warm enough or should it be gunned a few times to get things cooking??
Get the MOT Tester to do the emissions check first, and give it a good 30/45 minute drive on dual carriageways/motorways if you can to get the cat/exhaust as hot as it is going to get, and all the sensors to be fully functioning as they should as well. Allowing it to idle, even when showing the temp probably isn't enough to get it through a PASS, where as a good "Italian tune up" more often than not is the difference between a pass and a fail, especially as it's only a small bit out. Do you have a copy of the emissions sheet you could post up?
Low RPM makes it worse, e.g. ticking over during test
Needs a good ragging to blow away all cobwebs!
depends what it actually failed on but i've had a few with lazy lambda sensors that can take a while on the fast idle for them to come down.
Car had just done a 30 min drive on the motorway, she was certainly hot.
I've no idea what the actual emissions were because it would have failed if it was left on test, say no more!
I've recently had injector problems but swapped them and it had just been on a solus scanner and that said about the misfire and no lambda issues.
I didn't think the pre cat lambda could adjust the feeling much and the maf sensor did most of the work?
Thought the lambda just trimmed it. Correct me if I'm wrong.
Lambda controls it really, as that is where the ECU gets it's emissions data from and then adjusts the fueling accordingly, the post-cat one doesn't matter so much. If money is an issue, you can try swapping the two lambda sensors over if the first one has failed and the second one is functioning as it should. They should have given you a sheet with what it failed on emissions wise, or did they abort the test? If so did they offer any thoughts on a fault? If it's lambda, the emissions sheet should point towards that in regards to the figures it shows that's the only reason I asked.
The test was aborted
He suggested a lambda problem but wasn't sure so thought I'd ask people on here with real experience on them.
I've a obd scanner that will tell me lambda readings but unsure what's right and wrong with what it shows up.
I've no fail sheet but he said 7% over on emissions and a blatant fail.
He assumed I'd smashed the inners out the cat, I'm on the assumption the cat is intact because the car came with a decat and the noise doesn't sound like it's cored out so I'll rule that out for now.
Get the car hot, and then take a photo of the O2 sensor readings at idle, and at a steady 2000rpm (if you can)...
I'd guess it's the O2 levels that are 7% too high... The pass figure I think is (max allowed) 0.300 so 7% over that is quite a bit, which COULD point to an empty catalyst, but could also point towards a failing lambda.
Bottom sensor is doing sod all.
Is that the lambda?
Scanner also shows cylinder 4 misfire.
Car is running fine though.
I clear it and it comes back.
O2S11 is pre-cat lambda
O2S12 is post-cat lambda
Those readings are very similar to mine, however I'm running a de-cat! (second sensor shows nothing as the information it's reading is identical to the first). How does the car run? And idle? If you delete the code, and it returns then you've certainly got a problem with cylinder 4. You could try swapping the injectors around to see if the fault changes cylinder (indicating an injector fault, just replace with new don't bother cleaning it). I'd start with that, and go from there personally...
not holding revs for long enough to see what lambda is doing, you need to scope it to see properly how it's switching.
they don't have maf either.
I confuse the maf and map.
I've swapped the Map as a precaution a few months back.
I'll fire it back up tomorrow and get a further reading for longer on what the sensor is doing and if it's not raining I'll swap injector 4 as I've spares.
