So I'm about 3,000 miles into my 182 ownership now and have been slowly working round the different components of the car bringing them back to life and next on the list is the steering.
The car appears to get easily 'pulled' into grooves in the road surface, and requires a lot of counter steering to keep it going where I want it to go; it also struggles over rough surfaces again with the steering wheel moving around all over the shot. Occasionally when the VVT kicks in it will also have a little wiggle if its in 1st or 2nd.
From my tests so far, I believe the track rod ends are getting past it, but by no means seem as bad as some of the others I have heard on here, so I shall get a set of those fitted- but I am also wondering if I should just fit the inners too at the same time as opposed to changing the ends and seeing if it improves?
From what I gather, changing the steering rack bushes is a massive ball ache...
Is it worth doing a full steering refresh?
