Clio 182 pro race 1.2s fitment
Car  megane 265/clio 182
Wanting some pro race 1.2 alloys on my 182 in 15" what ofset etc will I need ?
Rimstock are your best bet new, they supply the Ktec racing series?
330 delivered in 40 offset. Or you can order 35 and 60.1 bore but takes 5 weeks ish.
Thanks guys will look into it today gues 35 and 60.1 bore a little more expensive?
Same price just takes longer
Think the standard bore they supply is 73 with spigot rings to suit.
When you ring ask for Justin with regards costs
Any one know where I can get the bronze pro 1.2's from in 15"
Will 35 mean will come out a little further and won't need spacers any more?
Ordering wheels today. Ideally want to have no spacers but want the wheels out a nice distance but don't rub. Arches are rolled on rear. Is et35 what I want as still seen some people saying they got 5mm spacers on front? Cheers
Said justin wast about he's placed a order but taken no payment so will ring again tomoz
I bought these from Rinstock a month ago or so. £330 delivered, I spoke to Steve Cox.
What's the deal with the 60.1 bore? What does it mean? Looking at getting some 1.2's at some point so it'd be interesting to find out.
60.1 is the correct bore size for the clio. Hole in the middle of the wheel. Or the hub.
Anything lower than 60.1 won't fit unless machined. Anything bigger than 60.1 will need spigot rings. Say 73.1 centre bore
73.1 spigot ring 60.1
Ah right cheers!
So are the Ktec cup spec wheels not 60.1 bore seeing as they're for 182's? Would have thought they'd be readily available.
Think the ones from rimstock are 73.1 and will fit fine with the correct spigot rings, you can order/specify 60.1 but will take a few weeks.
The ktec 182 championship ones will be 60.1mm so that they don't require spigot rings and are stamped for the series.
I'm guessing you'd need proof of being in the championship to get them at their discounted price.
What size bolts am I going to want to use with these with that offset?
I just spoke to rimstock. They can match that price earlier in the thread.
For my 182 trophy
Is et35
7x15
60.1
Correct.
It's slightly lowered it won't rub will it?
There for the track.
Got fitted today currently left spacers on tho as stud conversion goes on today sticks out a little I thing but worried when remove spacers will sit in to far
