Jr driveshaft or genuine
Car  182
Boot split on drivers side and vibration when u accelerate. Ktec said genuines £147 or use cheaper brand like j&r any thoughts anyone?
Only the passenger. The main issue is the correct one. Mine being a 60mm bolt spacing. Best to ring them direct.
Misread your opening post, you need the drivers side.
Makes no odds though.
Was just checking opinions on them as at work ford ones are expensive and they seem cheap haha but saying that old one knackered so can try. Bearing sizes vary? I got 182 non cup if makes any diff?
Call them up to tomorrow and they'll sort you out. There pretty decent. Just make sure you don't get the boring bloke on the phone. You'll know who it is straight away as he is f**king monotone and dull 😂 Other than that, it'll all be good!
I've used them a few times now for various vehicles and never had an issue, put a pair on a heavily lowered bora a couple of years ago and it's still running fine
15mm. Oh hang on, not sure on yours.
There's two sizes, I'm going to assume yours is the smaller one.
The larger one is for a cup packed car, 15mm iirc and 44 teeth.
@STEVE.M
Correct, 15mm is for 182 with Cup pack.
Not sure why it would be included with a standard 182 shaft, as the wheel bearings have different Internal Diameters, unless they are not sure which ABS rings are fitted on what, so it`s cheaper to throw them in than post them out if incorrect.
Bumping this... have they resolved the issue with the long shaft inner joint catching the block?
