Non-existent radio reception- aerial base replaced
  Clio Trophy
Recently changed back to a standard CD player giving me bugger all radio reception. Read about the aerial base giving problems so I just replaced that today and it hasn't made a difference.
Could it be the aerial itself?
Louis
I Love Ed Sheeran
It's worth replacing as it could be knackered inside. For the cost of one. Either that or swap one over from a friends? Where you from?
Louis
I Love Ed Sheeran
I got good signal in my 1.2, but since fitting a stubby aerial in my 182 it's crap. You could get a booster
  Clio Trophy
Also worth mentioning, the car is a Trophy so it has the V6 spoiler but I only noticed recently that the boot struts the previous owner fitted allowed the boot to open too far and actually foul the aerial and spoiler.
I've since replaced the struts but if the aerial itself could be sensitive to getting stressed like that then it would explain it.
Louis
I Love Ed Sheeran
Worth changing over then mate. You say you just refitted the standard radio, what was the signal like on the headunit you removed?
  PH2 172
Driving different vehicles at work, I have noticed that radio reception is poor when I connect my phone to the power/lighter socket with some installations.
Try a dedicated power supply & earth arrangement.
@Patrick Bateman
  Clio Trophy
Aerial now replaced too and not a blind bit of difference. Still zero signal.
What are the odds on the radio itself being the issue? CD works fine and it goes through the preset stations no bother.
Louis
I Love Ed Sheeran
Try putting in your other headunit if you still have it. Where are you from? I have a spare you could try.
  Clio Trophy
I binned the aftermarket unit but there was nothing wrong with it functionally. Just not sure on the likelihood of the radio itself being duff.
It's an 'update list' which is what I should need for my car (2005) as far as I could find.
I'm in Carnoustie, appreciate the offer but I'll hold off at the minute.
  Clio Trophy
On the drive to work today there was the faintest of signals and it would find stations when searching through. It was fleeting though.
If it is the signal, what else could it even be with a new aerial and base fitted?
Coops Mk1
  Lots of Scrap...
Have you actually removed the radio again and made sure the aerial connection to the back of it hasn't fallen off when you slid the stereo into the dash?
  Clio Trophy
This is what I've got.
Please tell me there's just a cable in the wrong place.
Stay Puft
  Clio 172
The cliospor USB/lighter thing stops my signal from working, dont suppose you have that plugged in??
  Clio Trophy
It's the fact you must have disconnected the aerial from the other headunit too???
Can't honestly remember.
Having left it overnight and the cable hiding away out of view I must have just forgot. Just had the 3 connections in my head and that was me.
Gus
  182Turbo,DCi90
@Patrick Bateman can you tell me more about replacing the aerial base. What tools, how it's fixed and is there a connector of some sort . Also is there room to work without damaging the headlining.
Want to change mine but don't want to jump in to it blindly
Louis
I Love Ed Sheeran
I believe you can get to the aerial nut, by just unpopping the back of the headlining. I'm not sure how far the connector runs through underneath the headlining though to unplug it.
  Clio Trophy
The bit everyone forgot to mention in all the posts I saw was that one of the connections (there are 2, the easy one is within a few inches of the base) is right down the driver side C pillar. As in the video, you'll want to remove some of the boot trim and rubber cover on the top mount to allow a bit more movement to get access.
The base itself is simple enough, think the socket I used was 20/21/22mm, can't remember which. It shouldn't be too tight though. Plastic pry tools make all the difference for getting the headlining and trim loose without damaging anything like a screwdriver can.
