Drive shaft seized in hub
Car  ph1 172, Arctic182
Trying to do a split abs ring but the passenger side splined shaft is well stuck in the hub, tried smacking it but with a 4lb lump hammer it will not budge. Any tips short of draining the gearbox and taking the shaft out to get it pressed out?
Sent from my SM-G903F using Tapatalk
Grrr..this car has been so reliable for 5 years, starting to be a pain now
I did it about 4 years ago so it's not a bad thing
Hub puller over the end of the shaft may be enough to free it off, would give constant pressure rather than just the impact from a hammer
Hub puller plus BFH helped me before with a similar issue on an MX5 where the disc was stuck fast onto the hub.
Bloody loud bang when it finally let go!
Be careful using a lump hammer on it, don't want to damage the threads. I had a similar issue at the weekend on my Mini, I used a socket over the hub nut (with the nut backed off), a lump hammer and some heat. It eventually went.
Yep, if you're going to hammer it out, always thread an old driveshaft nut on a good few turns first. Means the nut gets fucked before the shaft,
Got the bu##er off! Nut back on and a copper hammer, not sure how much abuse the bearing can take like that though?
