Hi all....
I've got play in my steering wheel, mostly up and down and it's quite bad.
I can see that there are ball bearings missing on the column which are about 2/3mm thick, these are what's causing the play on the column itself I believe.
You can see the area I mean by looking at the pictures below
My questions are..
Has the black outer case on the column broken or got a part missing
How do I go about fixing this?
New column?
If I need a new column, what needs replacing and what part numbers etc.
Thanks all
My questions are..
New column?
Thanks all
