Strange vibration?!
Car  Clio 182 cup
Hi guys, I bought a racing blue 182 cup last week and it has this strange thing where on the motorway when doing a steady 70ish occasionally I will start to feel a small vibration and If I accelerate it gets worse and worse and feels like the car is going to rattle its self apart but the second I let off the throttle and put my foot back on the power it’s gone! Even to the point where I can feel the small vibration starting I just blip off an on the throttle and it goes immediately. It had a new front tyre recently so I got the balancing checked on both front wheels and it’s still doing it since! Anyone experienced similar? Only thing I can think is a drive shaft?
A weird kind of 'wobbling' sensation that increases as you accelerate and lets off when you come off the accelerator might well be a dry CV joint sticking-and-releasing-and-sticking-and-releasing (etc) as it rotates.
Check your CV boots and, if they're fine, it could be worth peeling them back to make sure the joints don't need re-greasing.
It's normally pretty consistent, though, so I'm not quite sure if it might be something else in your case.
Thanks for the reply, the fact it’s so inconsistent is what’s confusing me but I jacked it up earlier and noticed the inner cv boot on the drivers side has thrown all its grease out so that must be the cause of the problem. That driveshaft is bolted to the block too which would explain the vibrating of the whole car!
I’ve got a load of upgrades and bits I want to renew on the front so just going to stick 2 new driveshafts in it while I’m at it so I know it’s all good for the future
Cup, Cup pack & Trophy are all 60mm centre to centre of the bolts that attach the front shock absorber to the hub knuckle.
Standard 182`s are 54mm.
15mm wide ABS rings is the big give away.
Ok thanks, so the 15mm abs ring is what I need to specicify for the new driveshafts?
Correct.
A word of caution, where your inner CV boot has split and thrown grease all over the back of your engine has been a problem with the RH J&R shafts with the support bearing.
Something to do with the boot being oversize/wrong spec and catching on the back of the engine block.
You could try and get a good price on a Shaftec item, R396R from a motor factor like Andrew Page, the ones on Ebay are too much.
Or you can grind the pointy bit off the engine block.
I`ll see if I can find a picture.
Correct.
Ok thanks for the help! I did notice earlier that the boot is very close to the engine block! Just don’t want to spend the earth on new shafts
Correct.
Been trying to get an answer out of j&r all day on if they actually have the correct shaft for my car as I’ve read that not only is my abs ring wider the shaft is actually longer too? Do you know if anyone with a cup has actually had a correct one from them as I’m loathed to just use their reg checker on their website as not sure if it would pick up the details of it being a cup!? Otherwise looks like Shaftec will be the way to go, do you know their part numbers to both side shafts for my car? Sorry to be a pain I’m new to all this clio stuff and just want to fix my issue aha!
Shaftec numbers are LH R396L & RH R396R, but unless you get someone to quote closer to the £72 I paid 3 years ago, you may as well get genuine ones for £157 from K-Tec.
£152 for Shaftec on eBay is having it away.
Someone said that at one time, J&R just sent out the same shafts for 182/182 cup with both ABS rings in the box.
@imprezaworks has a LH J&R 182 Cup shaft, but neglected to make a note of the part number.
I seem to recall that the guy at J&R to speak to is Lee.
I can get them for about £75-80 once I return my shafts but there isn’t a branch partially close to me, j&r won’t let me speak to anyone on the phone but has assured me that my reg brings up the right ones, and they come with both size abs rings, all I can do is order them and see I suppose
Just ordered a pair on their website using my reg, fingers crossed they’re right when I get them and can solve this issue!
I`m fairly sure there is no difference between the shafts of the PH2 172/182 `s except the width of ABS Rings, and the one piece RH shaft of the 172 Cup.
Shaftec no position Overall length J&R no Vehicle
R209AL LH 657 mm DS20 172 Cup (2mm difference??)
R218AL LH 655 mm DS248 172 PH2,182 7.5mm ABS ring
R396L LH 655 mm DS248 182/182 Cup 15mm ABS ring
R209AR RH 740 mm DS21 172 Cup with no support bearing
R218AR RH 730 mm DS249 172 PH2,182 7.5mm ABS ring
R396R RH 730 mm DS249 182/182 Cup 15mm ABS ring.
Essentially then, any LH shaft will fit, and any RH shaft other than 172 Cup will fit, as long as it has the correct ABS ring.
It would appear than Renault produced a multitude of part numbers for these shafts, in an attempt to discourage aftermarket copies.
It does surprise me at how poor the whole driveshaft and CV boot path has been designed and manufactured. We've all suffered from split CV boots, boots coming off, grease flicked and splattered about on alloys, engine components, even disc brakes.
The 182 is the only car I've ever owned where such things are a common problem.
Genuine Renault don't do this on the inside the only problem is the outer cv joint clips come off after many years.
This review is so funny
Karen Shepard reviewed J&R Trading Ltd – 1 star
6 July 2017 ·
Who makes JR drive shafts ? They're the weight of a small moon and once fitted you'll get more vibrations than shakin Stevens greatest hits ! If your stupid enough to think 40 odd quid buys you a decent quality driveshaft think again , buy at your peril but make sure you have comprehensive AA cover for when they do let go 2 weeks after fitting.
Share
I’ve used j&r joints and shafts on previous cars before and personally had no issues, one was even on a 250bhp Impreza wrx and didn’t feel weak or make any strange noises
The OE RH item from K-Tek didn`t last 20k miles before the inner boot split!
The £72 Shaftec replacement has now outlasted it.
The j&r passenger one.
It probably was but I needed to drive it home so I bought one from my local lyodds motor factors for £10 delivered same day. Not had an issue since.
To add to this @STEVE.M my 172 Cup passenger shaft didn't have the big weight on like other 1*2's have. I order a genuine used item off a normal 172 thinking it would be the same but one with the weight arrived.
Unsure which is right or wrong but I seemed to believe from looking at other owners Cups that both 172 Cup shafts were unique in that respect. Clarification needed I guess, most likely exactly the same shaft length/type etc minus the weight itself
That's not going to fix the OP's problem if the shaft itself is past it. He's ordered them now anyway.
Under warranty they would of sent you a new one mate but at least it's done now anyway.
15 years down the line, who knows what USED shaft you received.
None of the aftermarket LH shafts have the nicety of the balance weight, nor for that matter does my std non cup 172, which I am assuming is the original.
Sod paying £264 per side for Genuine 172 Cup shafts though, which is price from K-Tec.
I`ve also noticed K-Tec do not list PH1 shafts, and have read they are NLA from Renault, but J&R list DS20/21 for 2000 172 & ph2 172 Cup.
I have always been under the impression that the Ph1 subframe is 10mm narrower than ALL PH2 subframes. but 5mm per side could work if you keep to standard camber.
  • Like
Reactions: Gus
