I meant the fact it's not listed in that diagram hahaeBay maybe? I'm risking 300 for now :grimacing:.
OhI meant the fact it's not listed in that diagram haha
That diagram doesn't match the one posted earlier.So I connected it up today and it doesn't work.
What have I done wrong?
Wired it up like this View attachment 1361545
Hmmmm, I assumed @Louis was using a single appropriate resistor based on his diagram, for example a straight 900 ohm resistor for the resume button....?That diagram doesn't match the one posted earlier.
For example, the resume button, when pressed, the grey and green should "see" the 680+120+100 ohm resistors in series
I think they did? I thought each of the original cruise buttons has one of those resistances integrated :up:.Hmmm yeah should work then if he has. Makes you wonder why Renault didn't do it that way?
I dunno, I was just going by the diagram you posted earlier in the thread lolI think they did? I thought each of the original cruise buttons has one of those resistances integrated :up:.
Ahhh, gotcha! I only posted that to show there was some tolerance in the resistances. Sorry to confuse :grimacing:. I did my wiring based on that diagram and it worked a treat though.I dunno, I was just going by the diagram you posted earlier in the thread lol
I'm not sure that's true, I think you need to take it for a drive!I'm right in thinking even without being at minimum cruise speed I'd be able to select 'o' and turn off the cruise light? It's an odd one
My observation is speculative, but I suspect Renault have used the circult depicted in the yellow diagram above because it is a better check of the system than individual resistors via each button gives you.Hmmm yeah should work then if he has. Makes you wonder why Renault didn't do it that way?
