Clio 172 ED turbo oil leak
  172 Cup,R8, Exige S1
Looking for advice on a engine dynamics 172 low boost conversion, I seem to have an oil leak coming from the oil outlet of the t28 turbo, I have spent time, cleaning and monitoring the leak, the oil return pipe has had a constant flow of oil showing on the pipe so I am adamant it's the seal on the turbo oil outlet. I have tightened the bolts/nuts/jubilees etc and it's made no difference. Is the seal easy to replace and can this be completed in situ?
  dan's cast offs.
depends what downpipe is on it and pipework, can be a doddle sometimes or nightmare others.
  dan's cast offs.
seen a couple, can sometimes be the return fitting size compared to the turbo. few things it can be though.
