Newbie
Car  Clio 182
Just bought myself a bog standard 182. 93k in pretty decent condition with the previous owner having it for 7 years. Apart from a service what else should I be checking? Belts and dephaser will need done as it has only really had tyres and brakes done. Any advice would be great.
  • Like
Reactions: Gus
First ever Clio or?
Definitely get the belts done asap, plenty of specialists about. Where are you based?
First ever Clio or?
Central Scotland based near Falkirk. Is the belts too much of a chew to change out in the car? If so what costs would I be looking at. Cheers
You need specialist tools to change them on the F4R engine mate, most garages will use generic locking tools and they will 100% not be timed up correctly.
All depends where you go really. I can't off the top of my head think of any Scottish specialists.
@Nik or @rctempire may know of some?
Do you have a service history with the car that tells you when the timing belt was last changed?
Definitely needs doing if not done for seven years though.
It is definitely due now. All history up to the current owner around 60k then he owned it for the last 7yr only really doing brakes and tyres, all of which he kept receipts.
