Front Cage (Safety Devices)
R29TJR
  2005 RB 182 Cup
Good Evening All,
I’ve recently secured a front section of roll cage for my Clio however I had a few questions:
1. Can you keep access to the front glove box? If so is it just a case of trimming the door? Any pics would be great.
2. Sun Visors. I assume you just just remove these.
3. In order to fit the cross cross, along the windscreen do you need to remove the rear view mirror?
Anyway here is a pic of how I cable tied it in place this afternoon!
Thanks in advance
Tom
Djw John
Scotland - South
1. Yup, trim just under an inch off the glovebox.
2. Yeah, gotta take the visors off
3. Nope, once it's on the feet it clears the mirror.
Mertin
  Ph1 172&Ph2 172 Cup
Is it the same fitting instructions as on their site? I just bought one last week
R29TJR
  2005 RB 182 Cup
PM me with your email address and I can send over fitting instruction that I got when I fitted mine last year
Thanks Marc.
Thanks buddy.
@H2MRK emailed me some instructions which I've attached, I hope he doesn't mind!
  • R017 roll cage fitting instructions.pdf
Mertin
  Ph1 172&Ph2 172 Cup
Thats ideal, thanks. Alot more comprehensive than the ones from the SD website
  A5 Coupe & Clio182
I've got the same issue with the Mirror, if you don't have the cage raised is there a standard way people are refitting the mirror?
R29TJR
  2005 RB 182 Cup
I took the mirror off when fitting the cage (there is a small clip at the back and then you slide it off) and then simply refitted it once the cage was in place. However I may remove the standard mirror and replace with a large motor sport item.
