Help! Water leak in passenger footwell
Car  Renault Clio
Hi! Hoping someone can give me advise.
I have a clio 2004 and for the past 2 months I've had a puddle of water in my passenger footwell every time there has been heavy rain.
I have unblocked the drains on the left side of the car. My windscreen was replaced over a year ago. And the sunroof was fixed last year for a leak there.
I've removed the carpet and the foam underneath (which waa drenched) last week waiting for heavy rain again. To find where the leak is. I've located it to under the dashboard (see photos attached where its circled I have actually seen water run in during heavy rain), the foam under there seems to be soaked too so this maybe where the leak is coming from and now I'm at a loss as to how to fix it.
It must be coming from the scuttle panel. Is there a drain in the middle that can get blocked. My drivers side one is fine.
The water is definitely rain water.
Can anyone suggest my next steps.
Thank you soooo much in advance
I would check the central scuttle drain outlet first, it can get clogged with dead leaves etc
At back of the engine -in the centre, run your hand down the sound deadening carpet until you find a small hole well down the back, pop your finger in there -there should be a rubber pipe outlet, give it a jiggle ans see if any water runs out, if you dont find it in there then it could have been ripped out before as these clogged.
If not that then the blockage could be in the scuttle, this requires removing the windscreen wipers and plastic scuttle to get at it.
LOL @STEVE.M
On topic... I also have the same with my dCi at the moment... behind the passenger seat is a soggy mess!
Being a 5 door and having a sunroof tells me it's going to be fun to diagnose... as after quickly popping the drivers scuttle off, the drain did look to be completely bone dry.
Cheers for the reminder as i need to sort my mums clio with the same issue
How did you get on Paul?
I spent 3 hours on the car tonight and found multiple leaks from so many places. Here's hoping I don't get this again tomorrow...
The whole passenger side including under the seat is saturated and the dark bits are actual puddles.. !
Havnt done it yet but mum is picking the kids up from school so will have the car at my house later so will try and do it then
I had/have the same issue. My car is now fully stripped. The water was coming in above the rear window somewhere (3dr). I removed the aerial and silicones it back on, didn’t work.
Removed the plastic trim on the roof above the window and siliconed the panel gaps, this helped a little. Now when it rains/it’s washed I get a litte drip which lands on the boot floor next to the passenger side rear damper. Defo comes from that back corner of the roof, I put it down to the water trickling along what ever pipe/wiring went from that point to the front of the car, my headliner used to get wet at rear pas corner & front pass corner. My rear footwell was never wet, just the front part. I removed a pint and half of water when I first noticed.
Edit: windscreen also replaced as the main culprit
