clio 200t / 220t brembo bracket
  Clio 182 trophy
Hi,
I'm looking at buying a Brembo bracket for the 220, is there any other company's other than PMS who sell this bracket?
Thanks
Ricardos
  LY 200 EDC
I believe there's one more company in Europe but they're more expensive. PMS are really the ones to go for, a decent kit which I had on mine.
  Clio 182 trophy
Ideal - do you know if its the standard disks with it or does the kit use other disks?
Ricardos
  LY 200 EDC
You leave your own discs on, it all just bolts on after you've taken off the OE calipers. You'll also need to buy the PMS brake lines to fit the Brembo calipers.
  Clio 182 trophy
Ok so the megane 225 braided lines dont fit then? al have a nosie tonight, seems cheaper to do than i though.
Ricardos
  LY 200 EDC
PMS have had them made to fit the OE Clio fitment one end and Brembo the other. It really is just bolt on parts bar bleeding the brakes, it doesn't take long to do. I renewed with new Motul 600 RBF brake fluid for trackdays, you need the 16mm spacers for the OE wheels to clear the 4 pot calipers.
You'll need:
PMS Brembo caliper kit
PMS brake lines
16mm spacers
R26 Brembo calipers
Mr Pink pins
R26 pads
Brake fluid
