Amos91
Honorary Member
Hi all,
Had a couple of weird faults with the car which I hope someone can give some pointers for:
1) Car sometimes bogs down around 2.5k rpm like it loses power but this only last a few seconds (happens quite rarely and mostly as its warming up)
2) Happened twice at the weekend, I dipped the clutch to change down whilst coming to a junction and the car cut out. Released the clutch and it basically bumped itself going again - very odd! All working fine today...
Plugged in the RsTuner and it said ignition fault across all the cylinders. I actually had this last year, replaced the coilpack with a GSF Vetech 'special' and all was well.
Before I go and buy a Valeo coilpack are there any other suggestions on what I should look at? With it being an issue across all cylinders it makes less obvious to figure out!
Cheers!
Cheers!
